Hi
Does anyone know if I am able to upgrade the processor and/or the RAM?
I think the maximum capacity for RAM is 2GB, but if someone can just confirm that.
Thank you.
Marc.
Solved! Go to Solution.
Hi Marc141,
yes the Maximum Memory supported in the VGC-RC202 is 2x1GB modules..
Thanks for that.
Would you happen to know if I am able to upgrade the processor and if so, which processor would be compatible?
Kind regards
Marc.
Hi Marc,
not sure upgrading the processor would make a great difference but the processor socket is LGA 775 shouldyou feel the need to proceed..
Thank you for the advice.
Kind regards
Marc.
