Where can i download a drive for a graphics card Ge Force FX Go5700 for Windows 7 32bit
Geoff
Solved! Go to Solution.
Hi Geoff and welcome.
I don't think you will find an installable driver to download.
You will need to download a nVidia driver and modify the .INF file to allow it to install. Even then I am unsure that it will work satisfactorily with Windows 7 - certainly any advanced features are unlikely to work.
Go to www.LaptopVideo2Go.com and read the 'Quickstart Guide' to see what is involved.
