VGN-CR11Z/R Maximum Ram
profile.country.en_IE.title
chromium
My G/F has a the model listed above in Candy Red and it came with 2gb of Ram and Vista installed.
I installed Windows 7 64bit on the system but would like to upgrade the Ram to 4gb. I've seen people selling 2nd hand models with 4gb installed, yet the information I get around the internet claims that the maximum system memory is 2gb?
Can I get a bios upgrade to allow 4gb? I'm competent with PC's and really want to swap the 1gb modules out for 2x2gb but this conflicting information is making me have doubts.
P.S: The unit seems to have two different names? It's listed as both the CR11z/r and PCG-5J1M??
Thanks in advance.
Tags (2)
Hi chromium and welcome.
Sony's Specifications for the VGN-CR11Z/R confirm that it supports 4GB.
http://www.sony.co.uk/support/en/product/VGN-CR11Z_R/specifications
The correct mode name is VGN-CR11Z/R.  The other model is a chassis number shared by several models and you will not find it used on any Sony website.
:wink:
austingrd
Goiod luck installing this Chromium. If it is your first time, I would suggest to do it with tech support over the phone just to make sure. https://imagicon.info/cat/12-13/vmware_happy.gif
