lakelander
VGN-FS215B
I have a vaio VGN-FS215B . This one has no S-video exit. Can I hook this up to my TV through VGN exit though?Thanks :thinking:
Hi lakelander and welcome to Club Vaio.
Your FS-Series has no video out connections. Basically you have three choices:
1. If your TV has a VGA 15-pin monitor input, you can use a monitor cable. Not many TVs have this VGA connection.
2. You can use a VGA to TV CONVERTER BOX to convert your VGA output to Video or S-Video.
3. The only other way is with a USB TO AV CONVERTER
:wink:
rich912
Hi lakelander
If you mean the VGA output then have a look here ...
Go n-éirí an bóthar leat
