VGN-NR11S BATTERY LAST ONLY 5 MINUTES...
spollak
Hello,
My VAIO battery doesn't seem to charge anymore.
It lasts only about 5 minutes when not connected to the main power.
Is there any test/anything I can do or do I need a new battery?
Thank you.
Thalamus.
Champion
Hi wilco16,
A simple way to check if this is a battery or possible hardware problem is to take your Vaio to a local stockist and ask if they have a similar battery, to the one in your Vaio, that you can try test in your Vaio..
