VGN-NS20E - No screen Flashing Lights
pcqhobbit666
A friend brought his laptop ove to mine to have a look at after it had a little accident.
Well he said little.  The screen is completly shattered so i can't see anything on the screen, i've tried external but nothing comes on there.
All i get is the Power and Charge LED flashing, the hard drive comes on when you press the power button.  But as soon as the screen lights up with it's shattered pattern it goes out.
Can't seem to find anywhere in the manual about the LED sequence.
Hope someone can help.
Neil
Thalamus.
Champion
Hi Neil,
welcome to Questions & Answers..:smileyhappy:
Unfortunately more than just the screen may have been damaged in the accident..:smileysad:
Do any of these help.?
The power indicator status is as follows -
Glows green when the Vaio is on,
Blinks slowly in Orange when in standby,
Off when the vaio is hibernate or turned off.
The battery indicator status
Glows orange when battery is charging.
Blinks fast indicates battery error.
Battery & Power -
Blinks along with the green power indicator when the battery is running out of power (normal mode)
Blinks along with the orange indicator when the battery is running out of power (sleep mode)
Have you tried pressing Fn & F7 as soon as the screen lights up as this may enable you something on the external monitor..
Thalamus.
Champion
Hi Neil,
Battery & Power -
