HI all just purchased an xl100 and have tried fresh install of vista ultimate
im having problems as it seems others with the maxell wireless connection when i reboot the pc after all the updates and installs it wont find any networks
anyone know of a current or upcoming fix for this issue?
that apart ive returned to mc2005 for now and am happy with the pc
Cheers in advance
JH
Hi JPH160 and welcome to Club Vaio.
The Marvell Libertas 802.11b/g drivers are meant to be part of the Vista Inbox and install automatically. Does the card show as 'working correctly' in Device Manager.
I have not heard of anyone else with this specific problem - there have been some intermittent wireless connection issues with Vista but I don't recall a total failure to detect networks. I suppose your router is vista compliant and you have connected the WLAN ariel securely?
For some reason Vista Ultimate keeps throwing up problems with hardware compatibility. Did you carry out a clean install or an upgrade from MCE?
Hi thanks for the reply
i tried an upgrade and a clean install in both cases the wireless card shows as working and finds the network then after a reboot fails to do so
shows as working in device manager but if you disable it it cant renable until a reboot
I have also now lost sounds on dvds through hdmi although optical is ok
i think i will have to go back to mce 2005
is home premium vista any better for problems?
JH
I thought I'd hijack this a little.
I've done a clean install of Vista 32-bit Premium on my XL100, and the wireless isn't playing ball. It's detected in Vista, but I get a "code 10" cannot start problem in device manager. Nothing I seem to do fixes this. No sign of any drivers updates (or at least none that I can find!).
Thankfully, I'm connected at gigabit ethernet speeds, so I don't need to rely on the piece of $%&* marvell card that Sony fitted to the XL100
