- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Highlight
Volume control problem
Sony Vaio Fe21VGNS. Worked great until yesterday but got a slight problem...
My volume control facility has been *lost* . My sound card is working as when the computer boots up , the sound appears. As soon as windows loads then it goes and for the few brief seconds I can get volume control - sound plays back absolutely fine. The following symptoms occur either via the buttons or the onscreen slider volume.
The 'Volume' visual comes up on the screen and I can adjust it but it rapidly and without any prompting goes back to zero. This volume visual also appears randomly on the screen upon key / mouse presses.
I've located one potential answer but it says that it is specific to windows 2000 and I can't find the specific registry line indicated in the solution suggested.
Any ideas, anyone?
M
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Hands and welcome to Club Vaio.
Are you using any third party audio programs such as Winamp or Media Player plugins that load at startup? If so make sure that the volume control for this/these applications are not set to zero.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
I had a similar problem. Took me 2 months to realise that the volume on Winamp was turned down low. :smileyd_oh:
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Accck,
Not winamp (installed uninstalled installed) ... I'm trying to track it down - any more suggestions?
BTW How do you view the start menu - I mean the programs that are loaded at the start....
Mx
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Click Start > Run and type msconfig in the Open dialogue box > click OK.
Click on the Startup tab – this will show all programs that load at startup. You may also wish to investigate the Services tab – services that load at boot.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks - still working on it - ahh it is vewry irritating!
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Turn all your Volumes to Zero,go in Control Panel,Sound/Audio.Turn all sliders to zero,then turn them up full.make sure the Speakers are set right and Sys Volume is on full.Save settings and exit to desktop.Then use the Volume Buttons to Control the Sound Output.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Thanks for the tip.
It worked for about thirty miniutes and the situation returned to the normal it has been for the past week. *sigh*
Tried to repeat it but the slider volume continues to return to zero on its own - whatever setting I put it on.
I'm wondering whether it has to do with the hot key / function keys on the keyboard - as I'm typing this the volume visual is flashing on and off my screen.
- Mark as New
- Bookmark
- Subscribe
- Mute
- Highlight
Hi Hands,
I am not sure whether this will have any effect but it may be worth re-installing the utilities that manage the keyboard controls.
Download the pre-installed utilities for your model from Vaio-Link and then install the following, in this order:
1 Sony Utilities (install folder 1)
2 Sony Shared Library (Install folder 2)
3 Vaio Event service
Then re-boot.
If this does not solve the problem fist time around then try the procedure a couple of more times….
