VPCCB3P1E Battery not charging
optical52
I run my laptop from the mains and have not had reason to run it off the battery
The battery is the original one supplied with the laptop about 14 months ago
Just over a week ago the info on the battery showed...84% available (plugged in, not charging)
It is now down to 80%
Do I take it that the battery is no longer any good?
If I continue to run it from the mains, should I be bothered?
thank you...
rich912
Hi optical52,
I would guess that you have Battery Care function enabled at a max. charge of 80%. Check in Vaio Control Center > Battery > Power Management > Battery Charge Functions. If this is the case then the battery will not charge until it drops below approx. 79% and stops charging at 80%. You can check this out by running on battery only for a while and then attach the adaptor to see whether the battery is reported as charging.
If you plan to use the notebook mainly on mains power then it would be advisable to leave Battery Care enabled to extend the battery life.
Rich
Go n-éirí an bóthar leat
rich912
Hi optical52,
Rich
optical52
thank you
rich912
You're welcome optical52:smileyhappy:
Rich
