Does any one can help?
When in auto Bright mode the bright is minimum, when out of auto mode goes to 100% maximum bright: Tried to use de Fn plus F5 or F6, the response was only one square up or down on the scale and no response on the screnn brightness.
Under Vaio Care the display test faillure "verify that the hardware accelerattor is set to the maximum value (E-VIDEO-008)". I did and the accelerator was on full mode.
Thanks.
