I have recently bought a Vaio desktop VGC-RC204 .
On the back of this pc are six sockets that I really can't find any documentation about. What are these sockets used for?
See image (attached, sockets depicted on top).
Thankful for help.
They are from the tv card
Hi challll,
Welcome to Club Vaio,
Page 45 of the RC204's manual may help you identify the various ports..
Hi challll,
Welcome to Club Vaio,![]()
In that case it the sound connections you are looking at, its probably a 5.1 sound card, the little square plug is for an optical audio out which is for hooking the PC up to a Surround sound amp.
HTH
HTH
The image that you have posted is not very clear..
Does this help identify the ports..
Have you got them all?
In addition to the ones in Thalamus's guide, (4 X USB plus Ethernet) you have a 6-pin Firewire socket.
