what transformer for 220 v laptop when in USA 110v?
profile.country.sv_SE.title
miasandg
I am trying to find some sort of transformer for my vaio laptop swedish voltage 220. I am in USA and need a downloader to voltage 110. Some information say I should NOT use any kind of transformer. Is that really so?
Answer is quickly needed, Please...
Sincerely
Mia
Hi Mia,
If you look closely at your Power Adapter you will see that it can accept any mains voltage input between 110 volts and 240 volts.
Your Sweedish power adapter will work OK - all you may need is an adapter to fit the US mains power sockets.
No transformer is needed.
:wink:
Hi Mia,
:wink:
miasandg
Hi Blencogo!
Thank you a million for your helpful reply. I will get an electric power socket to be able to use it here. Keep fingers crossed it will work :slight_smile:
