Which battery should I buy for my old vaio VGN-NR21S?
profile.country.pt_PT.title
iriestev
Hello.
I need a replacement battery for my laptop.
My vaio VGN-NR21S came with a VGP-BPS9/B battery, which no longer works.
This battery model is not displayed in the online shop. Probably is no longer sold.
How can I find out which of the recent battery models are compatible with my laptop model?
Ian
rich912
Hi Ian,
Batteries for your model are still available even though not direct from Sony.
http://www.batteries-mall.co.uk/index.php?main_page=advanced_search_result&sid=1&keyword=SONY+VGP-BP...
A Google will provide plenty of hits but make sure you are buying a genuine battery and not a cheap imitation...
Rich
Go n-éirí an bóthar leat
rich912
Hi Ian,
Rich
tetrapackage
That is right. I bought my spare battery from a computer/technical shop where they sell batteries for different laptops. I am just not sure if the battery is genuine or not. But it works until now.
