i had vista systerm,now .i want to set winxp in this computer ,what can i do?my computer is vgn-fe41m.
Yes, it is possible to have a dual boot between vista and xp. There are several places on the net that can give you step by step instructions.
Before you start make sure you have made recovery dvds in case something goes wrong.
Also, you'll need to download the xp drivers for your laptop (or equivalent).
Basically, the steps are:
1. resize your vista partition to create space for xp
2. install xp (easier said than done - it helps if you slipstream the sata drivers into your xp install cd)
3. create dual boot between vista and xp
Good luck!
