If i have a window up, like for writing an email, it randomly minimises, its very frustrating.
Ive had my sony vaio laptop for over a month now, and this has only happened the last two times ive had it on.
Any idea why this is happening and how i could stop id, its really very annoying!
Please help!
Jenny
Hi Jenny!
I had the same problem on my old notebook.
First you might want to make sure the sensitivity of your touchpad is set low enough. If it was set too high it tended to do interesting things by itself on my old one.
Depending on your windows it might be a preset hotkey you are using accidently when writing...(?)
Sometimes there are programms working in the background with the setting "always on top" but do not show anything. Maybe there is a programm running simultaneously which is not working propperly. You could check that in the "task manager".
All the best and good luck!
