Windows 7 and Vaio S/Ware reinstall??
mictaylo71
Just wondering if anyone can help,i'm hoping to get windows 7 on pre order,but,if its a clean install i'm just bothered about getting my vaio software back on that came pre installed,ie movie story,smart network,the back up stuff etc etc.
Can you reinstall off the recovery disc or download from somewhere,or lost forever??
I have a vgn-fw21L bought last december,
Thankyou
Thalamus.
Champion
Hi CoolTails,
welcome to Club VAIO.. :slight_smile:
Unfortunately if you do a clean install of windows 7 on your VAIO you'll loose all of the pre-installed applications.. :slight_frown:
