Windows 7 clean install on Xl202.... Help needed with keyboard please!
nencio
Hello,
I have clean installed Windows 7 on my XL202.
Everything went smooth and apparently Windows 7 found all the necessary drivers for the hardware installed on it.
But... I have a problem with the original keyboard: upon boot all keys on the keyboard work perfectly, but in windows only the left part of the keyboard produces the right letters, the right part does not produce letters but numbers!
I suspect the generic driver that Windows put for this keyboard is not right, but is this the problem? In case, where can I find the right driver?
Thank you for any help you can give me!
rich912
Hi nencio,
I am not familiar with this model but the problem you have would suggest that you have the Number lock (Num Lk) on.
If your keyboard has this function then try pressing the Num Lk key (to the right of the Fn keys) to turn it off and all should be ok...
Go n-éirí an bóthar leat
nencio
Ohh dear!!!
Yes Rich, you are right! It was only the Num Lk key that caused this problem!!!!
So simple that I could not find the solution myself, thinking that I did some strange thing during clean installing Windows 7... I am used to solve more complicated HW or SW problems, that I could not think the solution could be that simple.
I really appreciated your hint.
Thank you so much!!!!!!!
rich912
You’re welcome nencio.
I’m pleased that it was that simple. You are not the first and certainly not the last to be perplexed by this :wink:
