Windows 7 + Vaio
mictaylo71
Windows 7 + Vaio
Hi
When Windows 7 is released i would like to do a clean install,although i have all the drivers on my backup discs,i was curious as to whether Vaio would be doing an official Windows 7 upgrade guide for Vaio or any advice on doina clean install as i would really like to keep all the stuff it came with in December last year.
Such as moviestory,musicbox,etc,etc...
Or alternatively can you get a disc with software on via serial no. or something??
My model is FW-21L
Hi CoolTails,
Unfortunately I don't think you can have the options you would like.
If you do a clean install, you will lose all the preinstalled software. You can download Drivers and Utilities only. The preinstalled software is not downloadable or available to buy for licensing reasons.
To keep the software you must do an Upgrade to Windows 7.
:slight_frown:
