Windows 7
Fuckdustcharlie
Windows 7
I have just installed Win 7 on my VGN-A517S, Everthing is good exept cannot open DVD drive
without going ito my computer clicking on DVD drive and selecting Eject! Also hot key buttons do not work and volume up down buttons.
Thanks any help would be appreciated.
You need to install the Vista Utilties for your model (if they exist). I can't check for you if they are available because the Vaio-Link website is down again. Poxy Error again!
I'll have a look tomorrow.
:wink:
Thalamus.
Champion
I tried to check just after 11 but site was down already.. :smileyrolling_eyes:
Ah - it's working slowly this evening!!
Go Here: -
http://support.vaio.sony.eu/computing/vaio/downloads/updates/index.aspx?l=en_GB&m=VGN-A517S&os=7
And install in order:
Sony Ulils DLL
Sony Shared Library
Vaio Event Service
Setting Utility Series
You will probably need a few more for other things - like Wireless Switch Setting Utility if you use wireless.
:wink:
