hi all
i have a VGC-LM1E
the wireless keyboard and mouse are not detected
rest all works ok
Hi rubyred52,
Refering to you previous post - after installing the new hard drive have you used the recovery disks to reinstall the original OS? If not have you installed all the original drivers and utillities?
http://www.sony.co.uk/support/en/product/VGC-LM1E/updates
Rich
hi rich912
thanks for replying
the hard drive replacement you mention is in my VGC-VA1
i had it done at a local repair shop
i think he has installed drivers and utilities
everything seems ok except the TV isn't working
the media centre did scan and find channels but on trying to view them it first says decoder error
upon restarting the computer it again says application failure
i don't know what the problem is
please help
now for the wireless keyboard and mouse problem it's in my VGC-LM1E
the link you have sent me is for that?
i'll try to install any updates and get back to you
To help you determine whether the problem is because of your computer or the device, try the mouse or the keyboard on a different computer.
_______________
Life is too serious to be taken seriously
