I have a sony Vaio all in one pc, and recently changed the batterys in the keyboard, now all i have is 3 flashing lights and the keyboard is barely useable....
Any ideas???
You have pressed the 'CONNECT' button on the bottom of the keyboard?
I would try another new set of batteries and also clean the battery contacts rthoroughly.
If the battery light is flashing, the batteries are not providing sufficient voltage. Try a new set of batteries and make sure they are the same type.
Then press the 'Connect' Button on the bottom of the keyboard to enable the keyboard to communicate with the Vaio.
tried all possible ways already with key/mouse/moniter connect buttons with no luck and think your right about batterys, have some cheap nasty new ever readys in there so will go buy some copper tops now
no luck, new duracells in now and still all 3 lights flashing
