WRITE PROTECTED BIOS???
throbber1960
hi guys
im attempting to flash my bios. but it flags up "error write protected bios"....any help.
sony viao vgn ns20e
7 REPLIES 7
profile.country.de_BE.title
stephanius
I'm not sure what you are trying to do, but messing with the BIOS in ways not intended by the manufacturer is very likely to brick your mainboard. It's yours, so that is up to you, just making sure you know.
If you are trying to remove a set/forgotten BIOS password - contact the VAIO support - they'll sort it for you.
If you are trying to add any functionality to the BIOS which isn't there to begin with, the question is what you are trying to achieve - maybe messing with the BIOS isn't necessary for it.
throbber1960
thx for the advice.
im well aware of the dangers. i didt say i was messing with the bios??,..
i want to update my bios. ie flash.
but when i run bios exe i downloaded from sony it flags up the above error.
all i want to know if anybody knows why im getting that error.......nothing else.
stephanius
Ok, that's something entirely different. =]
Check which BIOS version you have now, by pressing F2 when the VAIO logo is shown during boot.
You might have the bios already, maybe via VAIO update.
You might have picked a different model when entering the support site.
If my guesses above are wrong, please post which BIOS version you have installed and which download you are trying to use.
throbber1960
stephanius
Ok, obviously it shouldn't give you that message then. I cannot say on the spot why it does.
According to the description of the BIOS upgrade, the only thing it does is add VT support.
Is that what you are after?
throbber1960
well may be i should has read more carefully because my cpu is not "VT-compatible CPU"...lol
so i dont really need the update
i would still like to no why its giving me that error
iv spent a long time on google hunting for a fix
a lot of people have posted asking for help with the same error
but with no fix
thank you for trying to help.........if you ever do stumble across the a cure please let me know
regards martin.
stephanius
You are welcome, I'll post here if I stumble across something useful.
