Hi everybody. Siple questions I have. Is it possible to upgrade my vaio to SSD drive, and if yes what schould i look for. I mean any special drive or just any 2'5" ?? Apreciate all answers.
Yes it is possible - at a price!
If you look here you will see some guaranteed compatible SSD upgrades for your model: -
http://www.crucial.com/uk/store/listparts.aspx?model=VAIO%20VGN-AW31ZJ%2FB&Cat=SSD
thanks for help. ok than. first i've done i opened laptop, there is second empty caddy for HD but.... i cannot see any slots(pins) to connet hard drive . Where can i get any instruction for my model??
thanks
omg /.... i have to put this...just found out guy who opened his vaio and discovered no empty caddy but no sata cable !!!!! is this for real, did sony left me with no second sata cable and now how to purchase it before HD arrives??? whe would i even foun one ???????????????
Message was edited by: mahryni10
Retrofitting an SSD into a notebook is only straight-forward when you are going to replace a standard form factor 2.5" mechanical hard drive.
Whenever you want to add an SSD to a regular HDD in a notebook, there will be problems. Let's look at the typical cases:
chassis offered only with SSDs - see point 4.
I hope this helps. Good luck with your upgrade!
Message was edited by: stephanius
