if there are any USB-devices connected to the notebook while starting the notebook, it doesn´t start. Interrupting the connection between notebook and USB device is one possible solution of the problem. Doing so, the machine will start properly.But there might be other ways for solving the problem?
Best regards
HK64
Please do not double post!
sorry, it was a mistake by using the forum the first time. it won´t happen again. However, thanks for your advice
regards
hk64:smileywink:
No problem.
