laptop => tv?
duc
laptop => tv?
Hi, i recently bought a sony vaio pcg k115z
it didn't came with a standard tv out. all i have is a port to connect a second monitor to my laptop. what is the easiest way to connect my laptop to a tv? is this possible via one of the usb ports? or are there other easy solutions?
thanks
Jay1
Does it have a yellow coloured jeck socket. if yes then u need to get a cable which is jeck to phoneno
duc
it's that simple? cool! thx :smileygrin:
robpaxton
You need a Sony VMC20FR AV Cable or equivalent. It is the same cable that is used for Sony video cameras and has 1@multipole jack at one end and 3@Phono/RCA plugs at the other (Red-right audio, White-left audio, Yellow-composite video)
