XL201 Problems with tuner and Vista Ultimate
naboonl
I have upgraded my XL201 to Vista Ultimate. Everything works fine accept the recognition of which tuner to use.
In MCE2005 I could select on the XL201 whether to use cable, satellite or DVB-T. On Vista this question is not asked any longer and Vista MCE automatically jumps to DVB-T.
But I need to use the cable signal.
Does anybody know how to solve this problem ?
Best Regards,
Leon
mediauser
Hi
I'm having the same problem, did you ever find the solution?
