Partilhe a sua experiência!
Caro jonypedrosa,
Não se esqueça que só consegue instalar o Sp1, se tiver instaladas todas as outras actualizações para o Windows 7...
Cumprimentos
Ola jonypedrosa e bem vindo ao forum.
Olhei no site da Microsoft e achei isso:
Steps to take before installing Windows 7 Service Pack 1
How to increase your chances of installing Service Pack 1 successfully.
http://www.pagestart.com/win7sp1steps021611.html
(Revised 2/24/11 - 5 new steps added to help insure success) some of which are listed below.
Update your device drivers to the most recent Windows 7 device drivers from your
computer manufacture's support web site (for your specific make and model)
Start by installing the chipset/motherboard driver follwed by the remaining available drivers.
Run the SFC /SCANNOW command. This will check and repair if necessary any critical Windows system files.
Click on Start/All programs/Accessories then
Right click on Command Prompt option and select 'Run as administrator'.
At the command prompt enter: SFC /SCANNOW
Run the System Update Readiness Tool:
http://support.microsoft.com/kb/947821/en-us
Try Renamng the 'Software Distribution folder': (This could be the cause)
http://www.pagestart.com/win7sp1steps021611.html (Step #10)
Also: Steps to take before installing Win7 SP1
http://support.microsoft.com/kb/2505743
Free unlimited installation and compatibility support is available
for issues related to Windows 7 Service Packs:
Note: Availability of chat, phone or e-mail support differs depending on your geographic location.
Some issues may require more advanced support for which there may be a charge: https://support.microsoft.com/oas/default.aspx?&gprid=14496&&st=1&wfxredirect=1&sd=gn
Windows 7 - Service Pack 1 – How to install Step by Step
http://www.pagestart.com/win7sp1sbs02201101.html
Learn how to install Win 7 SP1
http://windows.microsoft.com/en-US/windows7/learn-how-to-install-windows-7-service-pack-1-sp1
Win7 SP1: Installation tips
http://windowsteamblog.com/windows/b/bloggingwindows/archive/2011/02/16/windows-7-sp1-follow-up.aspx
Troubleshoot problems installing a service pack for Windows 7
http://windows.microsoft.com/troubleshootwindows7sp1
Tambem ha outra discussao sobre esse mesmo topico aqui:
http://forums.techarena.in/operating-systems/1395063.htm
Espero que ajudem!
Cumprimentos
obrigado pela ajuda
Poxa, que pena!
Acredito entao que no seu caso o melhor é entrar em contato com a Sony diretamente para uma avaliação do problema. Abaixo os detalhes de contato:
Assistência telefónica
(+351) 808 200 185
Assistência através de correio electrónico
Formulário de pedido de assistência
http://support.sony-europe.com/contacts/email/email.aspx?site=odw_pt_PT
Fax (+351) 21 891 20 01
Endereço
Sony Portugal, Unipessoal, Limitada
Alameda dos Oceanos, Edificio Rock One, Lote 4.62.01 - Parque das Nações,
1990 - 392
Moscavide
Cumprimentos
