Can you put multiple playlists on a walkman ?
darren137
Thinking about getting a walkman for family holidays however wondered if you can upload multiple playlists ?
Thanks.
Wrinklie1
If the media player you're using to sync with the Walkman, it should work. I know that Windows Media Player 11 can handle multiple play lists & when you sync with it the playlists get uploaded to the Walkman with the same name.
Wrinklie1
