Guidance on an Audio Network Speaker SUS-GR10iP
pavloinpaxi
Hi, I got a speaker from a Charity for using my old iPod and am impressed with it. But I found that it is set on 'Bass' which I would like to be able to change but a Sony Remote RMA-S1iP didn't come with it!  I have searched for a remote but not found one, so does someone know any way I could turn Bass off (& on) without the remote?  Regards, Pavlo
Pascale_F
Moderator
Hi pavloinpaxi,
Welcome to the community.
I'm just going to try to find some answers for you. In the meantime, maybe someone else in the community might have some ideas.
Thanks,
Pascale
The_Black_Rose
Specialist
Hi Pavloinpaxi ,
I believe there's a button for the Bass on the unit itself. I'd recommend having a look on page 9 here: https://www.sony.co.uk/electronics/support/res/manuals/4108/41088252M.pdf
Cheers,
The_Black_Rose
pavloinpaxi
Thanks for the tip, it is useful having the guide. I looked through all, including 9, but I don't think it added anything that showed a control for Bass on the main unit, just the 'indicator' which is a light. However it does mention using the 'remote' or an iPod for the operations so I did a search on my iPod and found that it has a function to reduce the Bass in output. I will try using the iPod function and that might help it but I do use an iPod Nano more and I think I'll still need a Remote. Thanks, Paul
