Hi there, my little Walkman just crashed and it also crashed my laptop...
I was copying 4 Audible files from it to the laptop, but only 1 file made it.
I managed to restart my laptop, but the Walkman froze with the message 'Do not disconnect' on the screen.
The Back/Home button (nor any other) doesn't work.
I can think of two alternatives:
1) If I do a RESET... will I lose everything that's on it? Silly question, I know, but I need to ask it...
2) If I just let it run out battery, will I still have the crashing problem coming back?
OK, thanks - much appreciated!
Lucia
Hi Lucia,
Welcome to the community.
I'll see if I can track down some assistance and it might be that someone else in the community has an idea in the meantime.
Thanks,
Pascale
Hi there Lucia,
using the Reset button apparently will not delete your files. I found this in the help guide here:
https://helpguide.sony.net/dmp/nwzb180/v1/en/contents/TP0000313464.html
Win_88
