MDR 1000x
profile.country.SE.title
r.ageray
MDR 1000x
How to connect the headphone to the app? Do you have any idea?
7 REPLIES 7
dnicuk
Hello,
Download the Sony Connect App to your phone.
Open the Connect App.
Make sure your phone is in Bluetooth pairing mode.
Turn on the MDR and enable the Bluetooth pairing mode.
Check to see if it has paired with your phone.
Check on Connect App for the MDR connection.
If you don't see it, do another bluetooth compare from your MDR to the connect App.
Hope this helps.
D
Ps: I have WH and WF Sony products.
r.ageray
I tried everything but still doesn’t work, really disappointed if it’s not supported by the app.
dnicuk
Have you tried contacting Sony Support in your country?
Alternatively contact the the place where you purchased the Headphones from.
Sorry that you are having these problems, hope you get it sorted soon.
dnicuk
Here is a link to the MDR 1000X Bluetooth pairing method.
https://helpguide.sony.net/mdr/1000x/v1/en/contents/TP0001176138.html
dnicuk
Unfortunately the MDR 1000X headphones are not compatible with the Sony Headphone connect app. Here is the latest list of compatible headphones.
List of compatible devices
(As of April 2020)
Update the software of your headphones to the latest version.
https://www.sony.net/elesupport/
Status icons on Dashboard
  Power off DSEE HX DSEE Codec
MDR-XB950B1
MDR-XB950N1
WF-1000X
WF-1000XM3
WF-H800
WF-SP700N
WF-SP800N
WF-SP900
WH-1000XM2
WH-1000XM3
WH-CH700N
WH-H800
WH-H810
WH-H900N
WH-H910N
WH-XB700
WH-XB900N
WI-1000X
WI-1000XM2
WI-C600N
WI-H700
WI-SP600N
I don't think the MDR-1000X is supported by the app. I've tried every method to connect but even though the phone connects, the app doesn't recognise the headphones
dnicuk
The MDR 1000x are not supported by the app. See list of supported Headphones above.
