Just got my new MX4 headphones. Can connect with Tablet & Phone.
Will not connect and play on my laptop or my desk top. with windows 10.
Have deleted all pairings on my devices so a clean start.
MX4 will not pair on my laptop or desk top.
my AKG phones pair up and play perfectly with no problems. Thinking of returning MX4.
its getting to be a regular thing with Sony these days.
Could anyone help a frustrated soon to be an ex Sony fan
Hello @Macrep,
I assume you are referring to the Xm4 not the "MX4" headphones, is that correct?
If they won't pair with your desktop computer, you may not have a suitable bluetooth driver onboard.
In that case you can purchase a small USB dongle which is up to the latest standards and pair your headphones that way.
- Nic
Hi Nic
Sorry about that, it is the WH-100XM4 headphone
Thanks for the reply. If that is the case then there going back.
Im not spending £350.00 for allegedly the best, only for me to have spend even more to get them to work.
When the AKG Y50BT work perfectly well.
Unless anyone else has another solution.
thank you
Hi sorry to hear of your frustration.
Have you installed the Sony Headphone Connect app onto your phone/tablet? If not then I suggest that you do so Apple and Android version are available to download.
Once you have the app installed, open it and follow the instructions displayed. You will probably be prompted to update the headphone software, there is an update for Bluetooth connectivity.
David
I
J,
I hope you can get it sorted by Sony soon.
I use Apple Macs, both of mine work using bluetooth via Tidal app. I don't have windows computers so I can't test them out for you.
David
Hi David
Thanks for your comments. I have just had my bellyful of Sony.
No response from Sony support apart from an e -mail promising a customer support specialist will contact me soon., 48 hrs and still no contact from them.
Going to return what I had hoped would be a treat for myself.
This will be the last Sony product I will ever buy.
Tried every suggestion on line re read the manual, even a local friend who is an IT specialist for his job is stumped, he said I have done everything that he would have done.
My AKG 50 BYT connect first time every time on all my devices. Cost half the price.
Seems buying what you thought was the best is no guarantee of success.
If it's not too late, could you tell us more about what isn't working compared to the AKG's given that you've mentioned they pair with both PCs now?
