My WH-1000XM4 disconnects from my pc and then won't turn on
DopeyDopeyDoo
My WH-1000XM4 disconnects from my pc without telling me it has lost connection. Then when I try to turn the headset off and on again, I can't get it to turn on. On a bad day this will happen every 5-10 minutes and I have to plug my headphones in the the charger and reset it by holding down the power and custom button every time. Is there anything I can do to fix this? ( my headset is up-to-date )
Tags (1)
SkyNet404
Specialist
Did you also try to initialize it? Or just reset it: https://bit.ly/3jpIDYV
Is it working fine on your phone? Or do you only use it for the PC?
