Hi
For some reason when I play my walkman after not using it for a bit the track plays but no sound? Then after a minute or so it starts to output. The track is playing, I just have to wait?! This is with headphones plugged in by the way.
Any ideas??
Hi there,
Can you try to reset your Walkman player. If the issue is not solved, charge the player for about 30 minutes, then try to reset again.
Let me know how you get on?
Best wishes,
Sean
Hi Sean
Thank you for the response.
When you say reset. Do you mean power off. Then back on? Or do you mean a full factory restore/reset?
Thank you 🙂
Thank you for your responses!
So far, so good. But the original problem was very random. I'll give it a day or 2 before I update you all.
Thank you guys 🙂
You're welcome
Fingers crossed
Hi guys
Unfortunately it hasn't worked. Just now I picked it up, switched hold button to unlock it, plugged headphones in and pressed play. Begins to play, you can see on the display, but no sound. 30 seconds or so later the sound will suddenly output 😕
