nw-a1000 software
profile.country.en_IE.title
sashajai
nw-a1000 software
ive lost the cd for my sony walkman nw-a1000 where can i download the software??
Hi sashajai and welcome.
What software are you looking for?  You will find all the available downloads on the Support website for your player here: -
http://www.sony.co.uk/support/en/product/NW-A1000/updates
:thinking:
5 REPLIES 5
:thinking:
psio-.
Hi I want to connect My walkman to my computer so I can mange the contents
psio-.
Been to that site nothing there for me doesn't do anything
psio-.
This site and Sony are bl**dy useless
jumpsuit
@psio-. Welcome to the Community :slight_smile:
(Even if we are apparently bl**dy useless.) :yahoo:
OK what OS are you trying to connect your Walkman to?
(e.g. is it Windows 7 or 8 etc.)
What messages are you getting?
Unfortunately the Walkman is  a few years old so there may be compatibility problms with the drivers for it.
For example if you go to the link in the post above (Which works fine by the way and is useful) and click the personal audio driver you will see this info about compatible operating systems:
Note this driver usually has to be installed for you pc to recognise the Walkman.
Sonic Stage software is no longer available either.
