NW-A45 charging via the mains electricity (help?)
monsterjazzlicks
Hi folks,
I have just purchased a Sony NW-A45 Walkman (from Amazon dot com).
Am I only able the recharge the device using the Sony USB-lead connected to my PC?  Or can I use a USB-mains-plug such as the model I use to charge my Amazon Fire tablet:
https://www.amazon.co.uk/Charger-Adapter-CHARGE-Connect-Tangle-Black/dp/B075SKSQ7L/ref=sr_1_3?ie=UTF...
Obviously not having access to a PC (as a charging device) when I am away from home is going to cause issues!
Thanks,
Paul
Keyboards / Composer / Arranger
14 REPLIES 14
monsterjazzlicks
Hi IamNic,
Will this Amazon charger also be suitable for charging my Sony Headphones please:
https://www.sony.co.uk/electronics/headband-headphones/mdr-zx770bn?bvnotificationId=c254664c-96b8-11...
Thanks,
Paul
IamNic
Hello @monsterjazzlicks,
yes, it will.
If your phone uses a USB-charger, this one will work as well.
- Nic
monsterjazzlicks
Hi IamNic,
So you do not ever concern yourself over such factors as 'charging-rates', etc?
Thanks,
Paul
IamNic
no, since universal USB-chargers communicate with the connected device and don't let any more power trough than the device demands.
- Nic
monsterjazzlicks
OK, cheers Nic!
