Does NWZ-A10 series support MicroSDHC & MicroSDXC memorycards?? And if so what is the max. capacity???
Solved! Go to Solution.
Hi Maker1992,
welcome to the Sony User Community Forum..
You mention NWZ-A15 in the title & NWZ-A10 in your post..
Looking at the specifications of the NWZ-A15 your Walkman can support the following..
Then why it doesn't appear on the list of features when you try to compare A10 & A20 models (Finnish website version) ??
I have no Idea..
NWZ-A10 appears to be the series name but looking at the user guide it covers both the NWZ-A15 & A17 models, therefore they both should support the same micro SD cards..
