The message you are trying to access is permanently deleted.
Hello ay have radio sony srf-18 and ist good radio ay want to sam one ,do you have this radio samone ?
Hi there
Unfortunately it is hard to read your post/message, i dont think the english translation worked very well in this occasion.
Ay use gogle translate bat it not translate very good
Hi @cosmingpx8
I wonder if you wanted to ask if someone has this radio
and you wanted to know what it is like before you buy one?
If 'yes' there are lots of reviews online including this site
Hope this helps lol
Hi ay bay this radio ist ok thx for your mesages
