I love this speake because of it's sound and I hate it becuase of it's crappy software!
I start Music Center and the click on the speaker icon, after about ten seconds it's ok to play with bluetooth.
I want to use Spotify connect instead so I click on Spotify in the list and then I try to connect the speaker to Spotify Connect in the Spotify app. I have to push connect in Spotify software several times before it actaully connects, anoying!
Often it returns to bluetooth! Why? I want only to use Spotify Connect NOT bluetooth.
Why can't it remeber that and not change back?!
When it's playing from Spotify it suddenly drops the Spotifty Connect and I have to do the connection a couple of times again. Sometimes I have to reset int and set up the Wifi connection all over again, with WPS. Because the normal way doens't work anymore!
It's so frustrating and now the warranty is gone, I thought it was something that could be fixed with FW updtaes but it's not better after two years!
