Hi! I have lost my AUX cable that followed with my MDR-1ABT headset. Other AUX cables dont work. Where can I find a cable that works?
Hi there
Ive just been looking in the manual for these headphones and all I can see is "Headphone cable"
Headphone cable (approx. 1.2 m (47 1/4 in.)) (1)
I can only assume this is a 3.5mm to 3.5mm cable. The only other thing I found is this:
You need to call Sony support service, because despite MDR-1ABT still uses a regular 3.5mm jack, it needs to be plugged in deeper. As a consequence the tip of the connector is a bit longer than regular cable and you can't use a regular 3.5mm to 3.5mm cable
