Hi
i have just got the Sony Walkman NW-E394, I have tried the normal earphones while using the radio function and all works fine, but i would like to use it with my epic2 sports earbuds via Bluetooth, I cannot seem to find any Bluetooth icons so is it not possible to use Bluetooth with this device or is there a way round it, thanks
Solved! Go to Solution.
Hello @Tomcat9,
according to the specifications on the product page it doesn't look like the headphones have bluetooth capabilities.
- Nic
Hello @Tomcat9,
- Nic
Hi and thank you for your advice, I will just use the normal earphones that came with it, cheers
