Is there any way that we can switch the device the head phones are connected to without having to disconnect them from the current device first.
So frustrating that if it is connected to my laptop and I pack up to leave the office I can’t just switch it to my phone. I have to stop on the street, get out my laptop, disconnect and then reconnect.
Surely there is a way to control what they are connected to using the app? Or by pressing and holding the power button to switch devices/ cut the Bluetooth connection.
Hello @BarnabyG,
if you use a windows-laptop, you can press "Windows" and type in "Bluetooth" - if you then toggle it "off" before putting your laptop in your bag, the headphones should automatically connect back to your phone.
Aside from that there is no easy solution to that unfortunately.
- Nic
