Walkman Not Arranging Album in Correct Order
I'm having a bit of bother from my Walkman (don't know the make, but it's 02:17 right now so I'm not looking).
With this recent ablum I've bee trying to add, my player doesn't seem to want to to place it in the correct alphabetical order. It should be placed among the 'Do' section, instead it is placed inbetween the 'Da' and 'De' section.
In the photo attached, you'll see that I've added the letter 'e' to the beginning in an effort to see if it would be moved into the 'E' section, which it hasn't.
This shouldn't be happening.
Does anyone have a solution to this?
Tags (2)
Sean_Mc
Moderator
Hi Dave,
In order for me to try to help, I would need to know the full model number of your Walkman?
Best wishes,
Sean Mc
Marino.Manolo
Genius
I'm just using the logic on that image, will not the two points create the problem?
Manolo
