read2read
Walkman NW-A45
I have a, Walkman NW-A45, have purchased a SanDisk Ultra 128GB to use in the player.  Have formatted the SanDisk in the player, connected the player to my Macbook Air, then loaded my music onto the SanDisk. When looking for the SanDisk on the player, it says, SD mounted, but it also says, No Files on SD!  Have taken SD out & back in, but still no music on it, have deleted/reformatted SD in player, still no music!  I have connected SD card reader, with SD in, to Macbook & all the music is there, on the SD!  Can you help me please?
Sean_Mc
Moderator
Hi there,
Have you tried testing another memory card in the Walkman and let me know the outcome?
Best wishes,
Sean
read2read
Have tried another Micro SD Card, have formatted it in the Player, but it still shows no music!
When player connected to Macbook, I can transfer music on to player ok, until it is full.
Then have connected an SD Card reader, containing the SD Card to the Macbook, & then
transferred music directly to the Card. Clicking on the card, it shows the music on it, but
not when I put the card into the player!
Vanilla_
Hi read2read,
Have you tried to reset the Walkman itself? Maybe it's just a glitch with the player. Here are the steps for the reset: https://helpguide.sony.net/dmp/nwa40/v1/en/contents/TP0001449058.html?search=reset
Let us know if this makes any difference,
Vanilla_
