WF-1000X
I had my headphones stolen from my table at restaurant?
can these be traced?
are there any serial numbers on the box which could help identify them?
is their a way to log stolen on sony database to prevent function? something which should be considered in future generations, their not cheap
IamNic
Hello @franky1983,
there is no way to "track" the headphones - the reason is privacy - if you could track them, anyone else could.
Because of that such tracking features are not build into electronic devices, especially if they have no network capabilities which they would need to "tell" you where they are.
A smartphone for example can be tracked if you install the correct software on it, yet the headphones which only have Bluetooth to connect would have no way of telling you where they currently are in the case they get stolen.
- Nic
