So I have my WF 1000 XM3s and am pleased with how they work/sound etc but....
I can't seem to get Alexa on my phone working with them, the Sony headphone app only offers Google assistant, when I use the Alexa app, add device 'headphone' the app doesn't seem to pick the WFs up.
Am I alone with this? Can't take using Google assistant and this is annoying
Hello @Geekyhawkes,
have you set up Alexa as the default assistant in your Android smartphones settings? Maybe that helps: https://www.cnbc.com/2018/05/07/how-to-make-amazon-alexa-default-assistant-on-android-phones.html
- Nic
I have thank you, but for some reason these headphones seem to only want Google assistant - the Sony app for headphones only offers Google assistant, I don't see why they couldn't make this easy and offer the various assistants like android does without needing to play games with 3rd party apps.
Hello @Geekyhawkes,
I just checked the help-guide and there only Siri and Google Assistant are mentioned.
Looks like Alexa isn't yet supported from what I can tell. 🤔
- Nic
Disappointingly this would seem to be the case - hopefully Sony can fix this and get basic functions introduced in these headphones.
