WF-SP700N
WF-SP700N
My WF-SP700N is charging but after charging period is over my left headset is not getting on and only right one is on and because of which my phone Bluetooth is unable to detect the hradphones
4 REPLIES 4
Pascale_F
Moderator
Hi rakesh301086,
Welcome to the community.
I'll look into this for you and see if I can find out. Someone else in the community may be able to advise in the meantime.
Thanks,
Pascale
Vanilla_
Hi rakesh301086,
Have you tried to reset it to default settings after charging? The reset procedure is here: https://helpguide.sony.net/mdr/wfsp700n/v1/en/contents/TP0001613432.html?search=reset
Let us know if this makes any difference,
Vanilla_
brad96
I have the same problem, did you find a solution?
brad96
It seems the left bud is run out of battery, so no option can be applied, after I take it out of the charging case, there is no red or blue light, but there is always a red light when it is inside the case.
