Kent46134
Wh-1000 Xm3 "ping"
Hello.
I have haid my headphones for 2 weeks. Theres a high "ping" sound now and then. I dont now why, and i can not find any informations of this in the manual. Is there anyone that now what it is and if i can geet rid of it?
I saw in the instruktion on Sonys helpdesk that its possible to have vibration in the phones when there a call incoming.
I have not found that possibility in my app for android, any tipps?
Best / Kent
IamNic
Hello @Kent46134,
that is the so called 'adaptive Noise Cancellation' which notices when you start start to move or sit down.
You can deactivate it inside the Headphones Connect app.
- Nic
