When I try to make calls in a noisy enviroment (Mainly people talking around), I feel like the ANC is truned off and all the noise around me is clearly heard, plus the person that I speak to on the other end, can hear everything around me and maybe better than my voice.
I tried to adjust the setting in the Ambient sound section but it didnt really make any diffrence.
Note: I have updated the software version before even using it, once I downloaded the app and paired it with my device I updated it.
Please advise.
Thanks,
Hi there,
Hopefully a community member will be able to help.
Best wishes,
M
dude the update is the problem before update the ANC worked fine after it the headphones started to suck
How can I downgrade the software?
Hi shady.selim,
I think what you're describing here is normal. Usually, the microphone on the headset is used to gather nearby sounds and block them accordingly, but when you are on a phone call, the microphone is already occupied over the call, hence it's not possible unable to do its main function which is to block outside noise.
Regards,
Vanilla_
So what you're saying is that I can't use noise cancelling while on a call because all the noise around me will be heard through the speaker cuz the mic is on.
I never faced this before I think this is just throwing noise cancelling feature away which makes the headphone useless for calls.
