Followed the instructions in a previous post and the headphones came on. Turned them off to continue charging, red light came on and after a couple of minutes the light went off. How do I know if the phones are fully charged, is there a fault?
Solved! Go to Solution.
Hello @kernowsoul,
as you can see here in the documentation, they are fully charged when the red light turns off.
Quote:
- Charging is completed in about 4 hours (*) and the indicator (red) goes off automatically.
- Nic
Hello @kernowsoul,
- Nic
Thanks for your reply. I appreciate that the red light goes out when fully charged but I haven't charged the headphones for a number of months. I can only assume that I haven't used the headphones enough to deplete the battery.
Kernow bys Vikken
